Can Belimo NF-24SR Actuator Share Transformer with DMS MSC-MPC Controller?
  • Can Belimo NF-24SR Actuator Share Transformer with DMS MSC-MPC Controller?
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 02:35 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-19 08:11 PM
Can a Belimo damper actuator (e.g., NF-24SR) be powered from the same transformer as a DMS MSC-MPC Microsmart controller?
TAC IA Series
  • Belimo damper actuator
  • DMS MSC-MPC (Microsmart controller)
The MSC-MPC controller uses full-wave rectification, while Belimo actuators use half-wave rectification. Sharing the same transformer introduces electrical incompatibility, which can lead to component-level damage in the MSC-MPC controller.
  • Do not share the same transformer between MSC-MPC controllers and Belimo actuators.
  • Provide separate power supplies for each device to prevent electrical interference and potential damage.
  • TAC IA Series
Tags (2)
  • 3577
  • CraigEllis25
