Can a BS5308 part 1 type 1, 2 pair individually screened cable be used for M-Bus communications?
  • Can a BS5308 part 1 type 1, 2 pair individually screened cable be used for M-Bus communications?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-10 11:22 PM
M-Bus
Communication
Cables
A BS5308 part 1 type 1 cable was installed for Modbus communications, but it was then found that the communications were M-Bus
The correct cable to use for M-Bus is J-Y(ST)Y.  These indoor telephone cables transmit analogue or digital signals; Aluminium-laminated plastic foil static screen with tin-plated drain wire minimises the interference of high frequency, electromagnetic field;TP structure minimises crosstalk. For the datasheet please click HERE.
The BS5308 part 1 type 1 cable can be used, and the chart below shows the calculations used to establish this. For the cable datasheet, please click HERE.
For the Excel spreadsheet please click HERE.
Labels (4)
  • Satchwell BAS & Sigma
M-Bus_BS5308 part 1 type 1_20121127.zip
  • 11916
