Can Xenta controllers run on 24 Volt DC?
  • Can Xenta controllers run on 24 Volt DC?
‎2018-09-09 09:30 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:35 AM
What is the supported DC voltage on Xenta controllers?
Xenta controllers
DC Voltage is available for power.
The table below list the supported Voltage DC specifications for Xenta controllers
For more information check Data sheets for Xenta controllers located on The Exchange.
Xenta Controller Volt DC Support
411 19-40Vdc
421 21.6-40Vdc
451 21.6-40Vdc
471 19-40Vdc
491 19-40Vdc
400 Series 19-40Vdc
300 Series 19-40Vdc
200 Series 19-40Vdc
500 Series 19-40Vdc
700 Series 19-40Vdc
900Series 19-40Vdc
101 No Vdc Support
102 No Vdc Support
103 No Vdc Support
104 No Vdc Support
120 series No Vdc Support
  • 5201
