Can Infinet controllers share information when there is no Network level controller?
  • Can Infinet controllers share information when there is no Network level controller?
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:58 AM
Can an i2920 and an i2857 be used together without a CX controller?
  • Infinet
  • Stand Alone
  • i2
Want to install a control system without a Netcontroller.
Infinet controllers that reside on the same infinet bus are able to share data when the parent Infinity controller is offline or removed from the bus.
  • 11508
