Can I use one SQL database with two Vista servers
  • Can I use one SQL database with two Vista servers
  • PeterLarsen
    PeterLarsen
‎2018-09-06 12:37 PM
I have two Vista databases that log many points. Can I just use one full version of SQL or do I need one for each server.
Vista 5.xx
When more that 1 Vista server is installed each server will write and read from their own SQL databases.
Each Vista server requires a separate SQL database to write to. The SQL database does not need to remain on the server PC, it can be on a network pc the server has access to.
  • 7407
This is a heading
