Can Continuum or webClient be installed without the security key connected to the PC?
  • Can Continuum or webClient be installed without the security key connected to the PC?
  • AdamSteele
    AdamSteele
‎2018-09-06 01:58 PM
Need to install Continuum or webClient but do not currently have the security key.
Continuum
webClient
Need to install Continuum or webClient without the security key connected to the PC.
Yes, you will can install Continuum or webClient without the security key connected to the PC. You will however, require the key to be installed to actually run the Continuum Cyberstation or webClient server.
  • 4881
