Can Continuum Extended logging be configured on point with a Log Interval of less that 60 seconds.
  • Can Continuum Extended logging be configured on point with a Log Interval of less that 60 seconds.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:19 AM
  • Continuum
  • CyberStation
  • Extended Logging
The project spec calls for extended logging of point with a 5 second log interval.
While it is possible to configure extended logging points for intervals of 1 to 59 seconds, this is not recommended.  Continuum should notify the operator that this is not recommended when the point is configured.
  • 13529
