Calculate Heat Index in I/NET Seven
  • Calculate Heat Index in I/NET Seven
  • RandyDavis
    RandyDavis
  • Tom_Poovey
    Tom_Poovey
  • sesa139513
    sesa139513
‎2018-09-07 01:08 AM
Last Updated: Guinan RandyDavis Guinan ‎2021-10-26 10:02 AM
Is there a way to use points in I/NET Seven to calculate the "Heat Index"?
TAC INET
I/NET
Desire to use Heat Index information
You can determine the "Heat Index" within I/NET Seven. The only External points required are the following:
  1. Outside Air Temperature sensor
  2. Outside Air Relative Humidity sensor
Please see the attached Word doc that shows the Calculations involved:
  • TAC INET
Tags (3)
  • 2892
  • inet
  • TomPoovey21
