CSC - Help with checking the operation of this controller.
  • CSC - Help with checking the operation of this controller.
‎2018-09-10 03:34 AM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:54 AM
Checking operation of CSC.
Field Devices
  • CSC5252
  • CSC5352
The operation of the CSC compensator explanation.
The operation of a compensator is to adjust the system flow temperature, in relation to changes in the outside air temperature. The system flow temperature can be further adjusted by the addition of a room temperature sensor, which will provide room influence.
The CSC 5252/5352 controller is programmed with a complete set of "Default" settings, these settings will allow the controller to operate as soon as its powered up.
Although the controller has a complete range of adjustable settings, accessed through the "Fine Tune Mode", for a basic installation the "Quick Set Mode" can be used. The screen shot below explains how to enter the Quick Set Mode and the settings available.
Controller data sheet
Controller User guide
Compensated Flow Temperature Set-point:
The compensated flow temperature set-point is automatically adjusted based on a ratio for set-point adjustments against the outside temperature changes.
A consistent ratio across the entire outside temperature range, may not provide suitable control.
For example: with radiator type systems, radiators are less efficient at lower water flow temperatures and need to be provided with a higher temperature to compensate for this initially.
The “Set compensator ratio 1”and the “Set Ratio 2” settings provide the ratio of the change to the flow temperature set-point for changes in the outside air temperature, the ratio used is based on the “Set Change-over Value”, with the compensated slope starting from the “Set Flow Origin”.
The “Set Flow Temperature Set-up Value” and “Set Night Set Back Value” provide a constant adjustment of the flow temperature set-point to a given building control requirement.
The default settings would give a resultant flow temperature as shown follows:
The CSC5352 Calculator presents these settings in a graphical and listed format, making it easier to visually confirm the effects any changes to these settings would make.
  • Field Devices
Tags (2)
  • 6296
  • GaryMontague21
