Building Commissioning tool doesn't recognize VPN network
  • Building Commissioning tool doesn't recognize VPN network
  • JonGreen
    JonGreen
  • StephenYang
    StephenYang
Commander JonGreen Commander
‎2022-07-26 08:16 AM
Last Updated: Admiral StephenYang Admiral ‎2024-08-07 11:46 AM
Using a VPN, the Building Commissioning Tool is unable to recognize the network adapter
Building Operation Building Commissioning Tool
VPNs have not been specifically tested and therefore are not supported
  1. Though VPNs have not been tested and are not supported, some sites have found that this is possible. If the VPN adapter IP is available then it may work, if you have a VPN adapter that does not show up, please enter an enhancement request2022-07-20_10-06-58.jpgMicrosoftTeams-image (33).png
  2. If the above isn't available, run the tool after turning off the VPN application or Global Protect.
Tags (4)
  • bCT
  • ect
  • JonGreen22
  • StephenYang24
