Building Activate Partner Portal displays 'error: There is no change in the configurations'.
  • Building Activate Partner Portal displays 'error: There is no change in the configurations'.
  • Mukesh_Sangwan
    Mukesh_Sangwan
  • CraigEl
    CraigEl
Ensign Mukesh_Sangwan Ensign
‎2025-02-26 10:14 PM
on ‎2025-02-26 10:14 PM
While performing the verification tests, an error is displayed:
'error: There is no change in the configurations' as shown below:
EcoStruxure Building Activate
EcoStruxure Building Activate Partner Portal
This error occurs under the following conditions:
  • The user made changes in the Partner Portal but later reverted to the original settings/configuration, assuming there should be some changes, and then started the verification tests again.
  • The user chose to perform the test and verification process once post-submission, resulting in this error message.
When the verification process is initiated, it goes through four checkpoints. The user can safely ignore this error message and proceed with the tests directly. Clicking on the 'Load Mapping' button will remove this error message.
  • EcoStruxure Building Activate
  • MukeshSangwan25
