Builder for Function Block zoom settings retention.
  • Builder for Function Block zoom settings retention.
  • PeterLarsen
    PeterLarsen
Spock PeterLarsen Spock
‎2025-09-03 12:31 PM
Last Updated: Picard RobertAndriolo Picard ‎2025-09-03 04:12 PM
When opening a Function Block application in WorkStation, adjusting the zoom level does not retain the setting the next time the Function Block is opened.
  • Building Operation WorkStation v6.0.4 and earlier
  • Building Operation Builder for Function Block
There is currently no setting in versions 6.0.4 and earlier that allows the zoom level to be retained in the Builder for Function Block editor.
Starting with Building Operation 7.0.2, a new feature has been introduced that allows the default zoom level to be retained when reopening Function Block Program.
  • PeterLarsen25
