Bringing a Security Expert Module back online after a Firmware Upgrade failure
  • Bringing a Security Expert Module back online after a Firmware Upgrade failure
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2022-12-19 02:11 AM
Last Updated: Sisko GavinHe Sisko ‎2022-12-19 02:12 AM
Is there a way to bring an unresponsive/offline Security Expert module back online after a Firmware Upgrade has failed?
EcoStruxure Security Expert
  • Security Expert Controller
  • Security Expert Module
If there is an interruption/issue when upgrading firmware on a Security Expert module, the module itself can go offline and become unresponsive.
There is a 'hidden menu' in the Security Expert controller's web interface on the Application Software tab that can be used to 'Force Upgrade' an unresponsive module to 'try' and bring it back online.
The following video will illustrate how to:
  • Attempt to bring a Security Expert module back online after a failed firmware upgrade
  • EcoStruxure Security Expert
  • DavidKendrick22
100% helpful (1/1)
