Bin file Downloads fails on SCU and Mipped 7920.
  • Bin file Downloads fails on SCU and Mipped 7920.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 12:06 PM
Downloading to an SCU and a DPU 7920 Mipped board goes to 33K-38K and then fails.
All versions of I/Net software.
Possible bad memory location on the controller and or device that does not allow the device to be downloaded all the way.
  1. Change the address of the sublan device
  2. Download the bin file and database to it
  3. Go to Network Configuration and verify that the doors show up and can be saved
  4. Verify that the device functions normally again.
  • TAC INET
  • 8379
