Bad Reload Block Errors when trying to reload an AC256 series controller
  • Bad Reload Block Errors when trying to reload an AC256 series controller
  • DavidChild
    DavidChild
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:38 PM
Last Updated: Sisko DavidChild Sisko ‎2021-02-01 01:00 AM
When I try to reload a backup into an AC256 controller I get several Bad Reload Block errors with a hexadecimal code.
  • AC256
  • AC8
  • AC256Plus
  • AC8Plus
  • Poor serial connection.
  • Corrupt backup file
  • Insufficient line delay parameter.
Bad reload blocks errors when reloading an AC256 dump file can occur for several reasons.
Poor serial connection:
  • Try reloading from a laptop PC directly at the CIU to eliminate the serial cable run from the equation.
Corrupt backup file:
  • When a Bad Reload Block error occurs the first portion of the failed line is displayed.
  • View the backup file in Notepad.
  • Do a search for the code that was displayed with the error.
In the terminal emulation application (Hyperterminal, ProComm etc)  Increase the line delay parameter for sending text two or three milliseconds.
  • 5533
