Backup and Restore Process for Building Operation WebReports
  • Backup and Restore Process for Building Operation WebReports
  • RobertAndriolo
    RobertAndriolo
  • Derrick_Ratliff
    Derrick_Ratliff
‎2020-09-08 06:52 PM
Backup and Restore Process for WebReports
  • WebReports
  • Reports Server
  • SQL Server 2008 R2
Need detailed backup process
Refer to Online Help Topic for details
Backing Up the WebReports Database
  1. On the Windows toolbar, select Start, and then click SQL Server Management Studio.
  2. Click Connect.
    Note: When using a remote computer to connect to the Report Server SQL database, the Windows Accounts must exist on both machines and have administrative rights for the SQL database otherwise a successful backup will not occur.  In this instance, it is recommended to use the SysAdmin 'sa' login / password details when connecting in remotely.
  3. Expand the Databases folder.
  4. Right-click StruxureWareReportsDB, point to Tasks, then click Back Up.
  5. Under Destination, click Add.
  6. Click OK.
  7. In the Destination on disk box, select the backup destination.
  8. Click OK.
  9. Click OK.
Restoring the WebReports Database
  1. Ensure the Enterprise Server is up and running with the correct database.
  2. Stop the SQL Server Reporting Services and WebReports Agent (if installed).
    Note: If moving the WebReports Database it is recommended to restore the database then Install WebReports.  Then when Installing WebReports select Upgrade existing (as shown) and NOT New database
  3. Restore the WebReports database to recover reports data from backup.  This will include any Dashboard reports saved.
  4. On the Windows toolbar, select Start, and then click SQL Server Management Studio.
  5. Click Connect.
  6. Expand the Databases folder.
  7. Right-click StruxureWareReportsDB and select Tasks, then select Restore, then select Database.
  8. In the Restore Database dialog box, select the database set(s) that you want to restore.
  9. Click OK.
  10. Click OK.
  11. If not already installed now complete the installation of WebReports
Tags (2)
  • 12462
  • RobertAndriolo20
100% helpful (1/1)
