BCX reload error "Infinity controller error: Controller has no assigned Infinet port"
  • BCX reload error "Infinity controller error: Controller has no assigned Infinet port"
  • GavinHe
    GavinHe
  • Carl_Slack
    Carl_Slack
‎2018-09-06 02:15 PM
Last Updated: Sisko GavinHe Sisko ‎2022-08-25 09:12 AM
Reload of BCX receives error "Infinity controller error: Controller has no assigned Infinet port An error was detected while attempting to set an attribute in a remote Infinity object"
Andover Continuum
  • Continuum Cyberstation
  • BCX 9640
  • BCX4040
  • Infinet controller
  • b3
Reloading of a BCX 9640 resulted in error "Infinity controller error: Controller has no assigned Infinet port.  An error was detected while attempting to set an attribute in a remote Infinity object"
Suspected that a learn on the commport was performed or infinet controllers were manually created causing no assigned comm port.
As with any edit of the Continuum system, please make sure to backup the database.
Follow these steps:
  1. Send BCX to text file
  2. Add commport to each Infinet controller entry as below
  3. Import newly edited text dump file into the BCX.
  4. Reload BCX
Example of an original dump file exported in step 1 and the new dump file after the commport is added in step 2.
Original Dump File New Dump File
Object : Spare
  Type : InfinityInfinetCtlr
  LastChange : 1/11/2011 4:01:19 PM
  DeviceId : Zoo\GreenHouse
  Alias : Spare
  CreateTime : 8/24/2010 8:28:22 AM
  CreatedBy : Root\Acc
  TimeLocked : 2/15/2011 12:53:26 PM
  InstanceId : 7015/7167
  CntrlType : 851
  Description : Spare Controller No Points
  InfinetId : 1
  NetworkId : 11
  SerialNum : 12345
  VersionNum : 2.160000
 EndObject
Object : Spare
  Alias : Spare
  CntrlType : 851
  InfinetId : 1
  NetworkId : 11
  Port : comm2
  SerialNum : 12345
 EndObject
Tags (2)
  • 4382
  • GavinHeward22
