BAS2800+ Backup Not Available for the Site
  • BAS2800+ Backup Not Available for the Site
  • CraigEl
    CraigEl
  • DavidChild
    DavidChild
  • sesa125819
    sesa125819
‎2021-01-29 09:15 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-03 03:11 PM
A backup of the site is not available.
Satchwell BAS & Sigma
  • Satchwell BAS2800+
The site is operating in standalone mode, and no backup has been created or uploaded.
To recover site data, follow these steps:
  1. Review Node Configuration
    • Use the Pocket Terminal application to inspect the outstation node configuration.
  2. Configure Terminal
    • Set up the BAS2800+ terminal to match the configuration observed from the node.
  3. Transfer Files
    • Open BAS2800+ System Diagnostics.
    • Select the relevant outstation number.
    • From the Options menu, choose Transfer Files.
    • Transfer the file PNTFLE.REC from the outstation to:
      C:\BAS\Data\osn??\PNTFLE.REC
  4. Run No Index Utility
    • Shut down BAS2800+.
    • Locate and run the No Index utility (download link below).
    • This utility will create the index file.
  5. Restart and Verify
    • Restart BAS2800+.
    • Confirm that the points are now available and can be displayed.
⚠️ Note: The No Index utility does not name index segments automatically. You will need to name them manually.
Downloads
  • No Index Utility – NewUtils2.zip
  • Satchwell BAS & Sigma
NewUtils2.zip
Tags (3)
  • 6596
  • CraigEllis25
  • DavidChild19
