BACnet Service Tool license request in Windows 7
  • BACnet Service Tool license request in Windows 7
  • Alan_Wood
    Alan_Wood
  • AbeMeran
    AbeMeran
‎2018-09-06 01:26 PM
Error Generating License Request Cookie, Error code 0x1009 when generating license request under Windows 7
Generating a license request for the BACnet Service Tool under Windows 7 requires string value in the window's registry.
Windows 7
BACnet Service Tool
Windows 7 environment
Follow the following procedure to add a new String Value for the ProductId.
  1. Click on the windows start button and enter regedit in the 'Search programs and files' field.
  2. Expand HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows. (for 32 bit machine). For 64 bit machine expand HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows.
  3. Right click on CurrentVersion and create a new String Value.
  4. Change the default name to ProductId and put any string in the value.
NOTE: After the tool generates the license request, the path given to the location of the file must be pre-pended with C:\Users\usernamehere\AppData\Local\VirtualStore
Tags (3)
  • 5908
  • roam
  • roamio
