BACnet MSTP Wireshark capture
Schneider Electric StruxureWare Building Operation AS using MSTP for BACnet
Example of Wireshark capture and WriteProperty in MSTP
Using Wireshark, a bacapp.confirmed_service == 15 filter is applied which shows only BACnet WriteProperty packets
Below is a screenshot of the Wireshark screen after applying the filter. I have Requests (REQ) and Acknowledgements (ACK) shown:
Below is a Request, and clarification on what is Requested. A third party Metz (address 91) device is requested from the AS (address 0) for Analog Value 1 to be 0.00
Below is a Request, and clarification on what is Requested. A third party Metz (address 91) device is requested from the AS (address 0) for Analog Value 1 to be a value of 100.00
Filters which may be useful:
| Capture Filters | |
| udp port 47808 | BACnet/IP packets on UDP port 47808 |
| udp port 47808 or udp port 47809 | BACnet/IP packets on UDP port 47808 or 47809 |
| Display Filters | |
| bvlc || bacnet || bacapp | all BACnet packets |
| bacnet | BACnet NPDU packets |
| bacnet.mesgtyp | BACnet Network Layer (router) packets |
| bvlc | BACnet/IP packets |
| bvlc.function == 0x0b | BACnet/IP Broadcast packets |
| bacapp | APDU packets |
| bacapp.confirmed_service == 12 | readProperty packets |
| bacapp.confirmed_service==14 | readPropertyMultiple |
| bacapp.confirmed_service == 15 | writeProperty packets |
| bacapp.confirmed_service==16 | writePropertyMultiple |
| bacapp.confirmed_service==1 | confirmedCOVNotification |
| bacapp.confirmed_service==5 | subscibeCOV |
| bacapp.unconfirmed_service == 0 | I-Am packets |
| bacapp.unconfirmed_service == 8 | WhoIs packets |
| bacapp.unconfirmed_service == 2 | unconfirmedCOVNotification packets |
| bacapp.unconfirmed_service==3 | unconfirmedEventNotification |
| bacapp.unconfirmed_service==6 | timeSynchronization |
| mstp.frame_type>2 | exclude all token passing |
| mstp.frame_type>127 | view all proprietary traffic |
| mstp.frame_type==0 | only token passing |
| mstp.frame_type==1 | only poll for master |
| mstp.frame_type==2 | only poll for master responses |
| bacapp.instance_number==[BACnet ID] | all traffic from/to a specific ID |
| mstp.dst==[MAC address] | all traffic to a specific MSTP address |
| mstp.src==[MAC address] | all traffic from a specific MSTP address |
| ip.dst==[IP address] | all traffic to a specific IP address |
| ip.src==[IP address] | all traffic from a specific IP address |
| || (between filters) | combines above filters (or) |
| && (between filters) | combines above filters (and) |
Also check out the BACnet-Capturing MS/TP Traffic Quick-Help video on the Exchange.
