B4920 analog inputs read 8.6-8.9 volts instead of 10 volts for full scale
  • B4920 analog inputs read 8.6-8.9 volts instead of 10 volts for full scale
  • Alan_Wood
    Alan_Wood
‎2018-09-06 10:29 AM
analog input shows 8.6-8.9 volts instead of 10 volts
B4920
The pull up resistor when disabled will drop the top end voltage slightly
Pull up resistor on = 10 volts top scale
Pull up resistor off = 8.6-8.9 volts top scale (by design)
  • 13014
