Automation Server software cycle time
  • Automation Server software cycle time
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
  • PaulFr
    PaulFr
‎2018-09-06 12:07 PM
Last Updated: Picard RobertAndriolo Picard ‎2021-08-09 11:16 PM
How fast does the software run in an AS?
Building Operation Automation Server (AS, AS-P or AS-B)
Knowledge about application cycle time is important when designing project solutions.
Both Function Block and Script programs run at a speed defined by the specific time task they are linked to, the available tasks are:
  • Task 1 - 100mS
  • Task 2 - 500mS
  • Task 3 - 1 Second
  • Task 4 - 5 Seconds
  • Task 5 - 10 Seconds
Programs that are not cyclic or time based can be run from a main or executive sequencing program.
The AS cycle speeds are comparable to other Building control systems, but the power of the AS allows many more programs to be run in parallel at higher speeds.
See also the WebHelp topic Application Scheduler for more information.
Tags (6)
  • 8359
  • loop
  • PeterEdvik20
  • RobertAndriolo21
  • time.
  • times
