Automatically backup a b3 controller to flash
  • Automatically backup a b3 controller to flash
  • AdamSteele
    AdamSteele
  • Benji
    Benji
‎2018-09-06 07:38 AM
How to automatically have b3 controller backup to flash.
b3 Script Program
Script program syntax is a bit different to how it was done in Continuum, specific details needed on how to set this up.
This is a sample script program to enable automatic backup to flash when the controller database is different to what is currently stored in Flash.
Create the below Script Program in the b3 controller. Make sure to bind both the input and output variables to statusbackup/value.
'bind statusbackupin and statusbackupout to the systemvariable statusbackup/value.
numeric input statusbackupin
numeric output statusbackupout
init:
  if ts >= 5 then goto checking
checking:
if statusbackupin = backupneeded Then
  statusbackupout = backupnow
Endif
goto wait1day
wait1day:
  if td >= 1 then goto init
  • 19192
