Autocomplete Window Appears Off-screen in Script Editor
  • Autocomplete Window Appears Off-screen in Script Editor
  • RobertAndriolo
    RobertAndriolo
  • Katha
    Katha
  • JonGreen
    JonGreen
Commander JonGreen Commander
‎2020-06-22 04:11 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-12 10:05 PM
When using multiple monitors, the autocomplete popup in the Script Editor may appear off-screen, typically when the editor is placed on the right-hand display and in full-screen mode
Building Operation Workstation
This behavior is influenced by how Windows identifies and arranges your monitors. It can depend on:
  • The physical connection order of the monitors to the docking station or PC
  • The logical arrangement of displays in Windows display settings
To resolve the issue:
  1. Adjust Monitor Arrangement in Windows Settings
    • Right-click on the desktop and select Display settings
    • Drag the monitor icons to match your physical setup (e.g., left to right)
    • Click Apply to save the changes
  2. Swap Monitor Cables
    • If using a docking station or multiple video outputs, try swapping the cables between monitors
    • This can help Windows reassign the primary and secondary display order more intuitively
  3. Avoid Full-Screen Mode
    • If the issue persists, consider using the Script Editor in windowed mode rather than full screen as a temporary workaround
Tags (2)
  • JonGreen20
  • KatharineVasquez25
