Auto Report Generation not working
  • Auto Report Generation not working
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:45 PM
Trying to run an ARG (Auto Report Generation) and nothing happens.
I/NET
SevenReports
Unused fields may be preventing report from running
  1. When setting up the specific report, delete any unused parameters like date, time etc.
  2. Then delete any unused fields in the Select Expert field.
  3. Save the report and then set up the Options, Duration and Recurrence fields.
Once the time has elapsed based on the settings, the report should run and print or export to whatever device or format you selected.
  • TAC INET
  • 3133
