Audible alarms with I/NET 2000?
  • Audible alarms with I/NET 2000?
  • sesa139513
    sesa139513
  • Cody_Failinger
    Cody_Failinger
‎2018-09-06 03:21 PM
How can I get audible alarms with I/NET 2000?
I/NET 2000 site
First, in Control Panel, sounds, ensure that a sound is selected for default sound. That is the sound I/NET will use.
Second, if you cannot hear anything, and you have the amt configuration set for either timed or constant, it does work with the small speaker inside your pc.
The trouble is, it may be barely audible or your pc may not have a little speaker inside. If so, you may want to purchase a sound card and speakers.
  • TAC INET
Tags (5)
  • 1357
  • ChrisAsbury22
  • critical
  • off
  • setting
