Assa Abloy Continuum Integration
  • Assa Abloy Continuum Integration
  • Derrick_Ratliff
    Derrick_Ratliff
  • LeeCravens
    LeeCravens
  • Roger_Bently
    Roger_Bently
‎2018-09-06 08:42 AM
If using the Assa Abloy Integration for a Wireless Lock interface and pairing locks on Hub 11, only lock one is able to be paired at address 1 and functions correctly with older versions of software. No more locks can be paired after that although the Hub itself is able to handle more than one.
Andover Continuum
Continuum Version 1.94 and above
The version of software that is used for the application needs to be the latest version as compared to the older version 2.1.7. When this version is used the Hub only allows one lock to be paired although it is set for Multiple Lock Configuration.
When purchasing the applicable hardware from Assa Abloy, ensure that the version that is being sent out is the latest 10.2.28619.
  • 18350
