Arm and Disarm Area with Triple Badging at the Door
  • Arm and Disarm Area with Triple Badging at the Door
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2019-05-21 01:05 AM
Require method on how to Arm and Disarm an Area by Triple Badging at the Door.
EcoStruxure Security Expert
Security Expert
Require Door to be controlled by a Schedule but also to allow a valid User to override the Schedule with three consecutive valid badges.
Required Objects
  • virtual Output - Flag to control area status (v_TB_AreaArmedFlag)
  • Area - Area to control (TB_Inside_Area)
  • Programmable Function - Arms Area when virtual output ON (TB_Inside_Area_Arm_PF)
  • Programmable Function - Disarms Area when virtual output OFF (TB_Inside_Area_Disarm_PF)
  • Schedule - Operating hours of Area (TB_Schedule)
  • Door - Door to control Area status (TB_Entrance_Door)
Configuration
  1. Create virtual Output v_TB_AreaArmedFlag. Set Module Type to Output (PX) and Module Address and Module Output channel to ones that do not exist.
    virtual Outputvirtual Output
  2. On the Reader Expander > Reader 1 tab
    - Set Reader 1 Arming Mode to Toggle Function Output on 3 Reads
  3. Set Reader 1 Function Output to v_TB_AreaArmedFlag
    Reader Expander - ConfigurationReader Expander - Configuration
  4. Under Reader Options section set Allow Reading Opened/Unlocked.
  5. Under Misc Options section set Allow Access When Area Armed
    Reader Expander - Misc OptionsReader Expander - Misc Options
  6. On the Doors > General tab
    - Set Area Inside Door to to TB_Inside_Area
    Set Unlock Schedule to NeverDoor - GeneralDoor - General
  7. On the Options tab under Door Options 2 section
    - Set Door Lock Follows Inside AreaDoor - OptionsDoor - Options
  8. On the Area > Configuration tab under Schedule set Arm/Disarm Schedule to TB_Schedule
  9. Set Disarm Area When Schedule Starts
  10. Set Arm Area When Schedule EndsArea - GeneralArea - General
  11. On Outputs tab set Armed Output to v_TB_AreaArmedFlagArea - OutputsArea - Outputs
  12. Go to Automation > Programmable Functions and create TB_Inside_Area_Arm_PF
    - Set Type to Area Control
    - Set Mode to NormalProgrammable Function - Arm - GeneralProgrammable Function - Arm - General
  13. Under Area Control tab
    - Set Area Function to 2 - Area Arms on Output Turning On
    Set Output To Check to v_TB_AreaArmedFlag
    Set Area To Control to TB_Inside_Area
    - Save changes
    - Right-click TB_Inside_Area_Arm_PF function and select Start
    Programmable Function - Arm - Area ControlProgrammable Function - Arm - Area Control
  14. Go to Automation > Programmable Functions and create TB_Inside_Area_Disarm_PF
  15. Under Area Control tab
    - Set Area Function to 5 - Area Disarms on Output Turning Off
    - Set Output To Check to v_TB_AreaArmedFlag
    Save changes
  16. Right-click TB_Inside_Area_Disarm_PF function and select Start
    Programmable Function - Disarm - Area ControlProgrammable Function - Disarm - Area Control
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele19
  • AdamSteele23
100% helpful (2/2)
