Analog Input Configuration Objects (AIC) Description
  • Analog Input Configuration Objects (AIC) Description
  • DavidChild
    DavidChild
  • SaidSawan
    SaidSawan
‎2018-09-10 02:21 PM
Last Updated: Sisko DavidChild Sisko ‎2021-09-13 12:56 AM
Some AIC objects are pre-configured for the most common thermistors used in the industry. However in Building Expert, i cannot see the description of the AIC object until it has been added.
EcoStruxure Building Expert
  • Multi Purpose Manager
  • AIC
Feature not available on the MPM
The description of each of the AIC object is available below.
AIC1 to AIC10 = Empty (Manually configurable objects)
AIC11 = 10kOhm Type II Thermistor Celsius
AIC12 = 10kOhm Type II Thermistor Fahrenheit
AIC13 = 10kOhm Type III Thermistor Celsius
AIC14 = 10kOhm Type III Thermistor Fahrenheit
AIC15 = 1 KOhms Pt1000 Platinum RTD Sensor Celsius
AIC16 = 1 KOhms Pt1000 Platinum RTD Sensor Fahrenheit
AIC17 = 100 Ohms Pt100 Platinum RTD Sensor Celsius
AIC18 = 100 Ohms Pt100 Platinum RTD Sensor Fahrenheit
AIC19 = 1 KOhms Ni1000 Nickel RTD Sensor Celsius
AIC20 = 1 KOhms Ni1000 Nickel RTD Sensor Fahrenheit
  • EcoStruxure Building Expert
Tags (2)
  • 17259
  • DavidChild21
