An InfinityProgram called FiringOrder is seen in some b3 controllers.
  • An InfinityProgram called FiringOrder is seen in some b3 controllers.
  • BillNeville
    BillNeville
‎2018-09-06 10:17 AM
After drag/drop/copying a b3 to many other b3s an InfinityProgram called FiringOrder is listed with the other InfinityPrograms within some of the b3s
1.94 standalone, b3 VAV controllers
Appears something went wrong with the drag/drop/copy. Possibly tried to copy to too many controllers.
ContinuumAnalyzer identified the problem in the InfinityProgram Object Integrity Test and the Clean fixed it up.
  • 13632
