All new objects created are going into one folder instead of the controller
  • All new objects created are going into one folder instead of the controller
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:16 PM
Any objects created get placed in the folder
Continuum
Windows XP
Windows Vista
Windows 7
Windows Server 2003
Windows Server 2008
Selecting the checkbox for put object in folder and specifying a folder causing all objects to default to this folder.
By default, this checkbox isn't selected. To go back to normal functionality, uncheck the checkbox to 'put object in folder' and remove the specified folder.
When this mistake is made, not one single point can be named the same in similar controllers that are under that NetController or BCX.
This can affect drag and drop also.
  • 6231
