After installing a new badge printer new access cards do not print properly.
  • After installing a new badge printer new access cards do not print properly.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:57 PM
After replacing the badge printer with different make and model, Continuum will not print graphics on the badge.
When a badge is printed from Continuum, the card printer will issue a badge with no graphics printed on it.
Continuum CyberStation
WebClient
Zebra
MagiCard
EPI Designer
The printer has not been configured in that badge layout in EPI Designer.
Do the following for all badge layouts.
  1. From Personnel Manager, select Create Edit Badge
  2. From the Make/Edit Badge window, select Edit Badge Layout
  3. Select File > Page Setup
  4. Select the new badge printer.
  5. Select OK
  6. In EPI Designer select File > Save
  • 4919
