Advanced Display started in kiosk mode
  • Advanced Display started in kiosk mode
  • RandyDavis
    RandyDavis
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2019-11-08 01:36 PM
Last Updated: Guinan RandyDavis Guinan ‎2019-11-22 09:32 AM
When using Advanced Display and logging in to Webstation, it startups in kiosk mode with limited functionality.
Example:
Building Operation Advanced Display
When running Webstation in Advanced Display it is by default started in kiosk mode
  1. Open SmartX HMI Kiosk in Advanced Display
  2. In "Webstation setup" delete the part ?kiosk#
Example:
https://192.168.42.116/?kiosk#  Webstation be started in kiosk mode
https://192.168.42.116/  Webstation will start normally
  • JonasBrissman19
100% helpful (8/8)
