I/A Series R2 BACnet Binary Output Causes Functional Devices RIBTW2401B-BC to Drop Offline
  • I/A Series R2 BACnet Binary Output Causes Functional Devices RIBTW2401B-BC to Drop Offline
  • CraigEl
    CraigEl
  • WaynePeters
    WaynePeters
‎2018-09-06 12:25 PM
Last Updated: Administrator CraigEl Administrator ‎2025-12-09 08:02 PM
When adding a BACnet Binary Output object for a Functional Devices RIBTW2401B-BC RIB relay module in I/A Series R2, the device goes offline (status shows down). The output window displays:
ERROR: Unable to convert class tridium.foundation.dataspecies.DsEnum from ASN type 9
tridiumx.bacnet.asn.ASNException E_BACNET_ASN_INVALID_TAG {tagNumber 9 current tag 0}
BACnetDevice: RIB01 is now down
TAC IA Series
  • I/A Series R2
  • BACnet
  • Functional Devices RIBTW2401B-BC
The RIBTW2401B-BC device has an issue processing device status polling when priorityArray points are queried. It responds incorrectly to the UNC’s status message request due to a problem in its BACnet stack.
  1. Disable the device ping mechanism in the I/A Series R2 UNC’s BACnet Service → Device Status tab.
  2. Reboot the UNC after making the change.
  3. Ensure you backup the station when prompted to save the configuration changes.
  • TAC IA Series
Tags (2)
  • 7809
  • CraigEllis25
