Adding Older Unifact Pro Range With BB*2 Firmware to VisiSat
Select a Country
  • Adding Older Unifact Pro Range With BB*2 Firmware to VisiSat
  • CraigEl
    CraigEl
  • Gary
    Gary
  • Benji
    Benji
  • Dave_Shore
    Dave_Shore
‎2018-09-11 07:36 AM
Last Updated: CraigEl Champion ‎2025-11-05 09:13 PM
The default Unifact Pro stencil in VisiSat only includes items for the BB*3 range of controllers.
1.jpgIt does not include the older BB*2 range, which may still be in use in legacy systems.
Satchwell MicroNet
  • VisiSat
  • Unifact Pro
VisiSat’s default stencil set excludes the obsolete BB*2 Unifact Pro controllers. These must be manually added to the drawing environment.
To access and use the older BB*2 Unifact Pro controllers in VisiSat, follow the steps below based on your version of Microsoft Visio:
For Visio 2003/2007:
  1. Open Visio.
  2. Go to the File menu.
  3. Select Stencil > Open Stencil.
  4. Navigate to:
    C:\Satchwell\Binary\VisiSat\EN\Visio
  5. Select the file:
    Obsolete.vss
  6. The stencil will now include the older BB*2 Unifact Pro controllers.
For Visio 2010 and Later:
  1. Under Shapes, click More Shapes.
  2. Select Open Stencil.
  3. Navigate to:
  4. Choose:
    Obsolete.vss
Additional Notes
  • These stencils are installed by default during the VisiSat installation process.
  • If the Obsolete.vss file is missing, you can download it from the VisiSat 2.1 Build 196 (200, 201) Obsolete Stencil Archiv
  • You may store the stencil anywhere on your system, but the default location is:
  • Satchwell MicroNet
Obsolete.zip
Tags (5)
  • 18247
  • CraigEllis25
  • micronet
  • sigma
  • type
