Accuracy of I/A Series MN-Sx S-Link Wall Sensors
  • Accuracy of I/A Series MN-Sx S-Link Wall Sensors
  • CraigEl
    CraigEl
‎2018-09-10 07:54 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-25 07:35 PM
What is the accuracy of the I/A Series MN-Sx S-Link wall sensors? This information is required for project submittal documentation.
Field Devices, Satchwell MicroNet, TAC IA Series
  • MN-SX
  • MN-S1
  • MN-S2
  • MN-S3
  • MN-S4
  • MN-S4-FCS
  • MN-S5
  • S-Link
Sensor accuracy specifications are needed to meet submittal requirements for building automation projects.
Refer to document TPA-RKFD-09-0021.00 for factory-calibrated accuracy and stability specifications.
Sensor Specifications:
  • Element Type: Precision Thermistor
  • Operating Temperature Range: 0 – 50 °C (32 – 122 °F)
  • Stability: < 0.02 °C (< 0.04 °F) per year (typical)
Accuracy:
Temperature °C Accuracy Temperature °F Accuracy
24 °C ± 0.6 °C 75 °F ± 1.0 °F
0 to 50 °C ± 1.7 °C 32 to 122 °F ± 3.0 °F
Labels (3)
  • Field Devices
  • Satchwell MicroNet
  • TAC IA Series
Tags (2)
  • 7531
  • CraigEllis25
