Access denied and/or insufficient access errors reloading CX9680 or ACX2 (5720/5740)
Select a Country
  • Access denied and/or insufficient access errors reloading CX9680 or ACX2 (5720/5740)
  • Dave_Shore
    Dave_Shore
  • AbeMeran
    AbeMeran
‎2018-09-06 10:40 AM
Last Updated: GavinHe Champion ‎2023-02-13 05:51 AM
The above typically happens following an uprev of the controller FW to a different version.
Andover Continuum
  • CyberStation
  • CX9680
  • ACX5720
  • ACX5740
RAM Memory issue due to the difference between the two builds, this problem will be addressed in future releases of the FW
A similar warning can be seen if an XDriver is not correctly loaded. (Xdr may be referred to in the Distribution Properties page)
Remove the battery
Power down the controller, wait 5 minutes to make sure RAM is fully erased.
Power up and reload the controller once it is online.
Or reload the XDriver correctly first
Tags (2)
  • 12487
  • DavidShore23
