Access controller configuration on a Generation 1 controller
  • Access controller configuration on a Generation 1 controller
‎2018-09-10 04:45 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 03:57 AM
Since Generation 1 controllers do not have a controller webpage, how can I access the controller configuration to set up the controller or access controller information.
Andover Continuum
  • Hyper Terminal
  • CX9900
  • CX9940
  • CX9400
  • CX9410
  • CX9200
1st Generation Controllers do not have an embedded webpage.
Find information about the pin configuration of the direct connection cable in PinOuts for the RS-232 Connection of the older 1st Generation CX controllers.
The following document describes how to log into a generation 1 controller via a PC with a terminal emulation application: CX Operators Guide.pdf
  • 6571
