Access Expert Visitor Management Integrations and port requirements
  • Access Expert Visitor Management Integrations and port requirements
  • Alan_Wood
    Alan_Wood
Admiral Alan_Wood Admiral
‎2022-10-19 05:25 PM
on ‎2022-10-19 05:25 PM
Port information is needed for Access Expert Visitor Management Integrations
EcoStruxure Access Expert
Access Expert V3 Hosted
LAN port requirements for each VMS integration
Overview
The VMS connection is an important step to the setup of your VMS. Below is a chart of supported VMS and required ports. This article is valid as of 15 November 2019. It should also be noted that many of the VMS allow for the customization of ports and that is not be accounted for in this article.
Ports
OpenEye
Port
Usage
 80 TCP
2000 TCP
Center/Command Incoming Port
2002 TCP
Video/Image Incoming Port
2003 TCP
Search Incoming Port
9876 TCP
Clip Backup Incoming Port
3100 TCP
4007 TCP
Live Incoming port
80 TCP
443 TCP
3478 TCP
1024-655335 In/Out Range
Outgoing Ports
3001 TCP
4006 TCP
DVR Incoming Port
ExacqVision
Port
Usage
80
excaqVision Web Service (customizable)
8082
excaqVision Web Service - Web Socket (customizable)
22609
exacqVision Client computers communicating with exacqVision servers.
Default port 22609.
Milestone
Milestone maintains its own knowledge base with an article on ports.
Management Server service and related processes
Port number
Protocol
Process
Connections from...
Purpose
80
HTTP
IIS
All XProtect components
Main communication, for example, authentication and configurations.
443
HTTPS
IIS
XProtect Smart Client and Management Client
Authentication of basic users.
6473
TCP
Management Server tray controller, local connection only
Showing status and managing the service.
7475
TCP
Windows SNMP service
Communication with the SNMP extension agent.
Do not use the port for other purposes even if your system does not apply SNMP.
In XProtect Advanced VMS 2014 systems and older, the port number was 6475.
8080
TCP
Management Server
Local connection only
Communication between internal processes on the server.
8080
TCP
Management Server
9000(*)
HTTP
Management Server
Recording Server Services
Web service for internal communication between servers.
9993
TCP
Recording Server services
Authentication, configuration, token exchange.
12345
TCP
Communication between the system and Matrix recipients.
You can change the port number in the Management Client.
Port number
Protocol
Process
Connections from...
Purpose
25
SMTP
Cameras, encoders, and I/O devices
Listening for event messages from devices.
The port is disabled by default.
5210
TCP
Failover Recording Servers
Merging of databases after a Failover Recording Server has been running.
5432
TCP
7474
TCP
In XProtect Advanced VMS 2014 systems and older, the port number was 6474.
7563
TCP
XProtect Smart Client, Management Client
Retrieving video and audio streams, PTZ commands.
8966
TCP
Recording Server tray controller, the local connection only
9001(**)
HTTP
Management Server
Note: Every Recording Server service needs a port. Additional ports will be 9002, 9003, and so on.
11000
TCP
Polling the state of the Recording Servers.
65101
UDP
Listening for event notifications from the drivers.
Client components (outbound connections)
XProtect Smart Client, XProtect Management Client, Milestone Mobile server, Log Server
Port number
Protocol
Connections to...
Purpose
80
HTTP
Authentication
443
HTTPS
7563
TCP
22331
TCP
Event Server service
Alarms.
22337
TCP
Log Server
Server Logs (System, Audit, Rule-triggered)
Web Client, Milestone Mobile client
Port number
Protocol
Connections to...
Purpose
8081
HTTP
Milestone Mobile Server
Retrieving video and audio streams.
8082
HTTPS
DataCollector
Port number
Protocol
Connections to...
Purpose
7609
TCP
Recording Server
Collecting data
Avigilon
Port number
Protocol
Connections to...
50080
HTTPS
Server
55080
HTTP
Default Camera Device Port
80
HTTP
Streaming / Configuration
443
HTTPS
Salient CompleteView
Port number
Connections to...
80
6970-7225
Completeview Server for cameras using General RTSP/UDP
4242
Data
4243
Command
4250
Config Server
4255
Admin Service
4502-4534
Webserver (optional)
Wavestore
The default connect port is 8601. This is configurable.
  • EcoStruxure Access Expert
Tags (6)
  • Access Expert
  • AlanWood22
  • integration
  • ports
  • visitor management
  • vms
