Access Expert Identifying which version is being used
  • Access Expert Identifying which version is being used
  • Alan_Wood
    Alan_Wood
Admiral Alan_Wood Admiral
‎2022-11-28 04:29 PM
on ‎2022-11-28 04:29 PM
How do you determine which version of Access Expert being used
EcoStruxure Access Expert
Access Expert Hosted V3
Unsure which version of Access Expert is installed
When opening Access Expert new users may not know what version they are currently running. The following differences can help to identify the version being used.
Version 2:
  1. Uses a url e.g. http://seba.accessxpert.com
  2. The Hardware tree is on the left pane when selected
  3. Only five tabs on the header
  4. Icons are larger on screen
  5. No Folder View
Version 3:
  1. Uses an app that needs to be installed
  2. The hardware tree is on the right
  3. Seven tabs on the header depending on the license
  4. Icons are much smaller
  5. Folder view when enabled
These are just a few of the differences that are visible to help determine which version is being used.
  • EcoStruxure Access Expert
Tags (6)
  • Access Expert
  • AlanWood22
  • app
  • identify
  • url
  • version
