Access Expert 75-bit Wiegand PIV Class Card Format
Select a Country
  • Access Expert 75-bit Wiegand PIV Class Card Format
  • Alan_Wood
    Alan_Wood
Alan_Wood Leader
‎2023-06-02 07:45 PM
on ‎2023-06-02 07:45 PM
Instructions needed to configure the Card Format for 75-bit Wiegand PIV
EcoStruxure Access Expert
Access Expert Hosted V3
Steps needed to configure 75-bit Wiegand PIV Class card format
A site may have converted from Continuum or is a greenfield site needing to configure 75-bit PIV Smart cards. Below are the card format instructions:
Access Expert Card Format snapshot
Additional configuration tips:
  1. Keep Live monitoring open while configuring this format.
  2. Present a User's (Cardholder's) card and you'll see an "access denied entry".
    While setting this format, a "-1 as a facility code" will show when expanding access denied events while presenting a card in Live Monitoring. This is expected. LiveMonitoring -1 Facility Code.png
  3. In Live monitoring the encoded card number is shown.
    Type the card number into Notepad
  4. Copy the card number into the User's Card Assignments> Encoded Card Number field and Save.
  5. Repeat for each cardholder and Test
  • EcoStruxure Access Expert
Tags (5)
  • 75-bit
  • Access Expert
  • AlanWood23
  • Card Format
  • piv
