Access Controller SystemStatus toggling between NoComm and Normal
  • Access Controller SystemStatus toggling between NoComm and Normal
  • BillNeville
    BillNeville
‎2018-09-06 01:33 PM
NetController or ACX57xx system variable called SystemStatus is toggling between Normal and NoComm.  This may happen as often as every minute. This can be seen in a system variable listview or access event view displaying a door on that controller.
CyberStation
ACX57xx
CX99xx
CX9680
Controller cannot communicate with either the primary or secondary access server workstations.
Perform a teach from the primary access server workstation.
  • 5673
