Access Control with Card, Site, General Code
  • Access Control with Card, Site, General Code
  • BillNeville
    BillNeville
‎2018-09-06 01:15 PM
Can I set up a door in Continuum which allows either a card validation OR a general code validation?
AC-1 family
HID RK40 Reader/Keypad
Customer wants employees to access a gated area using their badges and the garbage company to enter a general code to get to the dumpster (they don't want to have to issue the garbage company a badge.)  Can the door object be set up to do this?
No, the access validation is coded as an "AND" not an "OR". What is meant by this is that when a door object is configured with the checkboxes for Validate Site, Validate Card and Validate General Code, the person must present a valid card and enter a general code - it is not either/or.
The easiest workaround for this is to add another AC-1,  another reader and create a second door with a different configuration. Different groups of people will be instructed to use different readers.
  • 6264
