ASP.Net is not showing as a user to select in dcomcnfg list configuring webclient on XP
  • ASP.Net is not showing as a user to select in dcomcnfg list configuring webclient on XP
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:33 PM
  • Windows XP
  • ASP.NET
This is usually caused because .Net was installed prior to IIS.
  1. Run the aspnet_Regiis.exe -i to re-register the .Net framework with IIS
    C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis.exe -i
  2. Go back into dcomcnfg and asp.net will now be available.
  3. This normally does not require a reboot or restart of IIS
Tags (2)
  • 3648
  • dotnet
