ACX5740 stops granting access until reloaded.
  • ACX5740 stops granting access until reloaded.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:57 AM
  • ACX57xx stops granting access through doors until the controller is reloaded.
  • Controller will work fine for a while then stop granting access again.
  • Controller has been replaced.
  • ACX5740
  • ACX5780
One power supply is powering both the controller and the controller strike outputs.
Install ACX57xx in conformance with the ACX57xx Controller Installation Instructions.
  • 14714
