ACWPPServerProxy applet is constantly flashing on webClient
  • ACWPPServerProxy applet is constantly flashing on webClient
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:45 PM
  • webClient
  • Loopback
This typically happens on a Stand Alone configuration on Windows.
The solution is to add the loopback address onto the IIS server by taking the following steps.
  1. Open IIS Manager
  2. Expand Web Sites> Right Click on Default Web Site and select Properties
  3. Click the Advanced button to the right of the IP address field
  4. Click the Add button and enter the IP: 127.0.0.1 and the port: 80, Click OK, OK
  5. Stop and Start IIS
  6. Launch Webclient and the ACWPPServerProxy applet will no longer flash.
  7. Restart the webclient PC
If you are using Windows 7, Vista or Windows Server 2008 the IIS interface is different.
  1. Open IIS Manager (the non 6.0 version) from Administrative Tools
  2. Expand Sites> Left click on Default Web Site
  3. In the far right column called Actions, locate the Bindings link
  4. Select Bindings and click the Add button then enter 127.0.0.1 into the IP address field (leave other defaults) Click Ok, Close
  5. With Default Web site still selection select "Restart" Under the Actions column to restart IIS
  • 3126
