AC256 ACNet Controller Firmware Compatibility
  • AC256 ACNet Controller Firmware Compatibility
  • DavidChild
    DavidChild
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:26 PM
Last Updated: Sisko DavidChild Sisko ‎2021-02-01 01:23 AM
Need to replace a failed PDU v3.3.  The only replacement available is firmware 1.7.  Will this work?
  • AC256
  • CIU
  • ACNET
  • PDU
A PDU v3.3 has failed.
A CIU III requires PDU Version 3.0 or higher.  Recommend changing out the firmware chip.
Version 1.7 firmware on an ACNET controller will result in impaired controller performance, specifically rotating drum programs will throw an interpreter error.
  • 5900
