A report has been copied from one PC to another and it is not working.
  • A report has been copied from one PC to another and it is not working.
  • Roger_Bently
    Roger_Bently
‎2018-09-06 02:55 PM
I/NET Seven Reports
This occurs because the linking for the report has been lost.
  1. Rename the report with the problem
  2. Copy the original report from the I/NET CD
  3. Paste it into I/NET Seven, Reports
  4. Right Click on the report and verify that it is not set for read only
  5. Run the report again
  • TAC INET
  • 2746
