A CX99xx does not show the SNMP option setting button on hyper terminal screen after the SNMP option is enabled.
  • A CX99xx does not show the SNMP option setting button on hyper terminal screen after the SNMP option is enabled.
  • SangKim
    SangKim
‎2018-09-06 01:25 PM
After a CX99xx is updated for SNMP option enabled, the hyper terminal screen does not show the SNMP option setting button when the hyper terminal PC is indirectly connected to the target CX99xx via other local CX99xx.
NetController (CX9900, CX9940)
This issue happens when the hyper terminal PC is indirectly connected to the target CX99xx via other local CX99xx.
After successful update the CX OS file for SNMP, connect the hyper terminal PC directly to the target CX99xx.
  • 5951
100% helpful (1/1)
