2.5MB size limit for default.db
  • 2.5MB size limit for default.db
  • SaidSawan
    SaidSawan
‎2018-09-06 09:13 AM
When the database (default.db) reaches 2.5MB in size, the MPM is not able to save the data to flash any longer.
SmartStruxure Lite Multi-Purpose Manager
MPM is not able to save very large databases
Reduce the size of the database by removing the least important trends or by decreasing the buffer size to 50.
  • EcoStruxure Building Expert
  • 17231
